entrecour Posted December 26, 2012 Posted December 26, 2012 Windows 8 32 bit - I use regional settings that do not match my actual geographic location, but my system clock is set to the correct local time. If I use the EPG Automatic time zone setting the EPG times are incorrect and the offset shown is incorrect (I guess it's using the regional settings rather than the system clock). If I use Manual to set the Time Zone difference there are two places this can be set - I assume I need to set in both, that's no problem in DVBViewer 5.0, but in RS 1.23 the offset is not saved. For the moment I am running these tests on the built-in admin account. If you want the support zip let me know.
entrecour Posted December 27, 2012 Author Posted December 27, 2012 So it seems that DVBViewer does use the system time zone somehow as I found that while my OS local time was correct, the OS time zone was incorrect. Once I had corrected the OS time zone the automatic time difference setting in DVBViewer and RS works perfectly.
