Problem to add up to 27500 symbol rate
lebucheron13
Hello,
I'm a user of DVBViewer TE2 (Technisat) and DVD viewer Pro. I try to add the news channel with a Symbol Rate up to 27500, like 29700. But when I scan, I do not get any channel.
I use an other application call Smart DVB, where once I add manually the frequence, I get all the channel on 29700 symbol rate for examnple.
Maybe I miss one option, so all advice are more than welcome
Thanks
Jean
The DVBViewer Pro scan window is misleading designed. It is not possible to ad new parameters via the scan window.
It s only possible to select which entries from the transponder list are used for the channel scan.
You need TransEdit add new entries in the transponder list.
Tjod,
Thanks for your quick answer. I will try that a soon as I found the download button/link for TransEdit...
do you have the link by anychance?
Sorry :-/
Jean
