webmaher Posted January 1, 2013 Posted January 1, 2013 Why external or any EPG dont show via Web Interface?
Tjod Posted January 1, 2013 Posted January 1, 2013 Do you import the EPG in the DVBViewer or in the Recording Service?
McenterFreak Posted January 2, 2013 Posted January 2, 2013 I don't know if webmaher are mentioning the same problem as I have. My EPG search in Recording Service has worked fine for years, but from yesterday, only Now and Next is loaded. I am a Canal Digital customer, receiving from 1 degree West. I've been in contact with Canal Digital. They tell me that they haven't changed anything. Total EPG is still on 10934 SR 24.500. The only thing I have changed is one of my FireDTV tuners was dead, and I replaced it with another FireDTV, and they appears to be working fine (Normal in Device status) What could be wrong?
webmaher Posted January 2, 2013 Author Posted January 2, 2013 Do you import the EPG in the DVBViewer or in the Recording Service? with Xepg i import EPG once a day in DVBViewer...
Tjod Posted January 2, 2013 Posted January 2, 2013 Than you need to change the Xepg settings. To import the EPG in the RS and not in the DVBViewer.
McenterFreak Posted January 2, 2013 Posted January 2, 2013 (edited) Moved to a new thread Edited January 3, 2013 by McenterFreak
webmaher Posted January 2, 2013 Author Posted January 2, 2013 Than you need to change the Xepg settings. To import the EPG in the RS and not in the DVBViewer. Thanks Tjod, its work excellent
