oldgraf Posted January 3, 2013 Posted January 3, 2013 Will devices like this plays tv stream from RS Quote
mague Posted January 3, 2013 Posted January 3, 2013 Most probably yes. Depends if its able to play TS streams. Since its supporting XBMC the chances are high. But you have to be aware that your bandwith is limited to wireless, which sometimes is not suffcient for HD streams. Quote
oldgraf Posted January 3, 2013 Author Posted January 3, 2013 (edited) Thanks I ask just because XBMC. Never touched XBMC on Android and dont know how is compared to XBMC live tv on x86. This device is just examle, I will buy another with LAN Edited January 3, 2013 by oldgraf Quote
alexdonc Posted January 23, 2013 Posted January 23, 2013 Is there an xbmc config file in DVBViewer RS? Quote
numa Posted January 23, 2013 Posted January 23, 2013 (edited) There is no support for Flash with android 4.0 and more, so no streaming with these products Edited January 23, 2013 by numa Quote
timetrex Posted January 23, 2013 Posted January 23, 2013 There is no support for Flash with android 4.0 and more, so no streaming with these products I uswe the dvdbviewer android app and I am able to stream on android 4.0 and above from the recording service..... Quote
numa Posted January 24, 2013 Posted January 24, 2013 http://readwrite.com/2012/08/14/adobe-flash-on-android-rip ... Quote
alexdonc Posted January 24, 2013 Posted January 24, 2013 It was the same for me - because I have a SGS2 and it still support flash. So.. something must be wrong with the new iPhone integration of web UI in RS in DVBViewer. That was my first statement. Before I was able to watch through web UI designed especially for iPhone on my Galaxy S2. Now, with the latest update I cannot. I have to use BubleUPNP only - and this way I miss the EPG. On the other hand there are of course advantages using a dLna client - a.s. you benefit of DVB subs plus there is no need to compress video whatsoever giving you a great experience. Quote
alexdonc Posted January 24, 2013 Posted January 24, 2013 Reinstalled the app and RS again, this time in Windows 8. The iPhone UI and flash support in my Galaxy S2 works again... I don't know what happened in Windows 7 after the update. So there is NO bug with the new version of RS. Thanks! Quote
