DVB Viewer 5 hanging on startup
Stephen
On my Windows 8 x64 machine, I have set DVBViewer to launch at startup by copying it's shortcut into the All Users startup folder. When Windows starts, DVBViewer launches, but then gets stuck on the initial splash screen with the "Completing Initialization..." message. The progree bar gets to about 95% and then stops. If I then kill the task and click on the icon manually, it's fine!
Is this an issue that anyone else has encountered?
Thanks in advance,
Stephen.
