timetrex Posted January 6, 2013 Posted January 6, 2013 Hey, I recently updated to DVBViewer 5 along with the latest recording service. Befor the update webpage for recording service would stream channels fine from flash on the browser. However, since I updated I can only do a direct stream, I can't play within the browser, the flow player keeps turning but nothing plays. Is there anything I can check to see what the casue of this? I should say recording service plays fine with direct stream and also within xmbc frodo...Any help appreciated.... thanks
Tjod Posted January 6, 2013 Posted January 6, 2013 Have you updated ffmpeg as well? It seams that there is a problem with the newest builds. Try a version from December 2012 http://ffmpeg.zeranoe.com/builds/
timetrex Posted January 6, 2013 Author Posted January 6, 2013 Yeah just started checkuing that out latest ffmpeg not working will try the one you suggested.
timetrex Posted January 6, 2013 Author Posted January 6, 2013 Have you updated ffmpeg as well? It seams that there is a problem with the newest builds. Try a version from December 2012 http://ffmpeg.zeranoe.com/builds/ cheers got it working. thanks for the tip...
