MarkVent Posted January 11, 2013 Posted January 11, 2013 Add: Subtitle Detection: Subtitles are detected in transmissions/recordings and listed resp. delisted if they (dis)appear. umm did a recording from UK channel ITV1 via satellite DVB card ... started the recording 5 mins early to ensure I catch the start of the show, this means I catch the adverts which do not have subtitles. When the program starts, DVBViewer 5.0 (recording the show via DVBViewer Recording Service 1.23) does not then pickup the subtitles when they start. The only solution so far is to extend the pre-record to 10 minutes to catch the end of the last program (which had subtitles) the subtitles are then recorded correctly. be grateful if someone could look into the issue thanks Mark. Quote
rasmuzzen Posted March 29, 2013 Posted March 29, 2013 Same story here, have tryied the options in recording services, nothing helps. Have no selectable subtitles on etc. Cmore, Disney or any channels, in select subtitles languages from text tv. Live TV works perfectly. Quote
rasmuzzen Posted March 29, 2013 Posted March 29, 2013 The recording service 1.25 beta did the trick, remember to enable all the option record ttv and so on again, it is not inherited from last install. Greetings and thankz from DK. Quote
