Automatic EPG searching cuts Dvbviewer while whatching
ramonchin
Hi.
I've followed Recording Service manual to install it correctly (setting my devices as unicast...), but when the EPG timer runs on background, DVBViewer turns to black for several seconds.
Am I forgetting anything?
I've a Tevii S660
Sounds as if the hardware devices are not set to "do not use" in DVBViewer. If only the RS has control over the hardware, collisions with epg update in the background should not occur.
It's set to "don't use"
Here is the support.zip
Try renaming the plugins folder. So that no plugins are used. Did it work than?
I'll try that but without some plugins, DVBViewer is useless for me.
