bingo Posted February 6, 2013 Posted February 6, 2013 (edited) DVBViewer V5.0.0.0 CCTV5HD channel info StreamID=44 I get 0KB file after recording CCTV5HD this Channel for a few minutes Recording time:00:54:54 File size:0.00KB StreamID=44 this is correct config(in image 2),you can get EPG info. No EPG info if you change StreamID Only I change StreamID:44 to 41,I can get correct record file. If I change StreamID to 0 1 2 3 33 100 42 43 44 51 61 or other numbers (not 41)........ then I also get 0KB record file. There are the same problems with the different channel in the same Transponder 578. I don't know why Can you fix it? Edited February 6, 2013 by bingo Quote
Derrick Posted February 6, 2013 Posted February 6, 2013 ..apparently your channel settings are wrong. A rescan could help. Quote
bingo Posted February 6, 2013 Author Posted February 6, 2013 ..apparently your channel settings are wrong. A rescan could help. Where is wrong setting? Quote
