Save EPG info of every tv show during recording
devildantej
Is possible to save in the .TXT file or .LOG file, the EPG info of every tv show I am recording?
My case is when I record 2 episodes in a row of the same tv show, I get saved only the last episode EPG info. I would like to get saved both episodes EPG info.
No, the only possibility is to generate one timer per show.
Can you consider it for future releases?
I'm not a developer.
And the request for such possibility, has been ask several times over the last years. But not added.
