Recording UK HD terrestrial TV
Pam
I realise that this is not a problem with DVBViewer but I'm hoping someone here might be able to help.
Is it possible to record, edit and encode UK Terrestrial HDTV as I cannot for the life of me work out how!
I have no problems at all with Satellite HDTV but I just cannot for some reason record or encode from Terrestrial - at least not the audio.
I can watch and hear it now (after installing every AAC codec I could find!) but when I capture, I cannot seem to encode the audio. I am using HDConvertoX.
I have the same problem with every other capture software I've tried so I know it isn't DVBViewer but something else.
I can give more details if necessary but I really would like to know that someone else is successfully capping, editing and encoding Terrestrial HDTV. I've been trying to work this out for months now both on a Win7 machine and a WinXP machine with both a Blackgold BGT3630 and a TBS 6280.
TIA for any help/advice/answers.
Hello i'm no expert but i record HD TV via my pcTV nanoStick T2 then edit with VideoReDo to remove ads plus you can use to re-encode to other formats
  • 1 month later...
If I have a transport stream containing the AAC codec, I have to convert it to ac3 in order to get it to play through my Western Digital HD player on my Pioneer TV. I do this using multiAVCHD - it seems to be able to convert the audio OK. It's maybe a round-about process, but it works for me. VideoReDo will certainly edit the stream - I use it all the time to trim start, end and remove commercials.
AC3 Filter as audio postprocessor is able to convert the AAC decoder output on-the-fly to AC3 if it is configured for PCM input (see property page -> system tab -> use AC3 Filter for PCM). The Postprocessor Plugin enables using it in this way in DVBViewer.
