PhilW Posted February 9, 2013 Posted February 9, 2013 For some time DVB duration of startup is in the order of minutes, (previously it was about 30-40 secs, at least not long enough to think something was wrong). The channel list I have in the editor is only 20 channels. Can anyone suggest what I can do to make the start up time shorter? I assume it is something to do with the channel list but I am not keen to try to delete it (how exactly)before I get some advice. Many thanks in advance Phil support.zip Quote
Tjod Posted February 9, 2013 Posted February 9, 2013 The reason is most most likely the Wake On LAN setting. Disable it if you don't need it. http://en.DVBViewer.tv/wiki/Options_Recording_Service#Send_Wake_On_LAN_to_service_PC Quote
