Sir John 2 Posted February 12, 2013 Posted February 12, 2013 I have a problem in so far that when I call up EPG (standard version not OSD) then it is in the Details view. It stays there, no matter what I do. The list of all stations is just not there. I have tried updating to Version 5.0 and have switched languages. No avail. I guess I have by accident changed a setting - does anyone have an idea what it might and where I find it ? Thanks Quote
Lars_MQ Posted February 12, 2013 Posted February 12, 2013 try the (rightclick) popup menu -> channellist visible. Quote
Sir John 2 Posted February 13, 2013 Author Posted February 13, 2013 Lars, thanks for that. I did not have the position in the EPG popup, but had it in the Timer menu (where it worked). Did not help. I found that Ctrl-H does the same - again worked on Timer, but not in EPG. So I did that what I have always done since 30 yrs on such problems - I reinstalled. This time with a new configuration and now everything is back to normal. Thanks Quote
