Scheduling repeating Recordings in RS web interface
McenterFreak
I would appreciate some changes to the way web interface in Recording Service handles scheduling of programs that are repeating. In this example I want to record every instance of a program called “Klovn” on a channel named “TV2”.
The way I do it now is:
Find the program in TV Guide
1 - Click on it
2 - Click Reruns
3 - Copy the text in Search For field e.g. “Klovn”
4 - Paste it into the Name Field
5 - Click on the channel in Channel Selection e.g. “TV2”
6 - Check the Add to Auto-Record search box
7 - Click Save
Then to record the actual program for today, I need to:
8 - Click Search
9 - Check the box left to the program name
10 - Click Record
It is all very complicated, and maybe I do it the wrong way. What I would like was:
3, 4, 5, 6, 8, 9 and 10 should be done automatically, so the only thing I should do was: 7 - Click Save
It could be a choice like Prefill automatically? So that the user could turn it off, if he desires to do it manually
If I do it wrong, then please advise me with a better way to do it, thanks
