DVBViewer DVB-T Stream server
Pedroid
Hi,I tested demo, and it looks well, but, what I need is to stream live TV, captured from external DVB T usb tuner to my android phone and TV set with attached minix neo 5. The Demo, does mot allow for using recording. Is it possible to make DVBViewer, broadcast or unicatst TV stream? Is it possible via recoding settings? What protocols does it support?
Thx in advance for basic info,..
P.
When you buy the full version, you can also download the "Recording Service". This will stream live TV, at least using DLNA.
If you look in the Recording Service forum, you will find some help on using Android.
