Which Dual DVB-T internal card?
mpohanka
Does anybody have suggestion for DUAL DVB-T INTERNAL card to buy which works in Windows 7 64 bit with last version of DVBViewer Pro without any problem? I have old AVerMedia A16A/A16AR PCI Hybrid DVB-T but it does not work with last version of DVBViewer Pro (after second run the hardware is not found, restart is needed) and it is also not DUAL DVB-T. I was using Pinnacle PCTV Dual DVB-T Pro PCI 2000I under Windows XP with older version of DVBViewer Pro 4.x but this card stop working.
my old HAUPPAUGE WINTV NOVA-T 500 works with me, still available
