Why I still use DVBViewer 4.9.0.0
Mostly Harmless
this is how window size changes in DVBViewer 4.9.0.0 when I change a 4:3 aspect ratio channel to a 16:9 and back
Window behavior in DVBViewer 4.9.0.0
and this is how the window changes in any newer version, including 5.0.
Window behavior in DVBViewer 5.0
am I the only one who bothered by this?
(n.b. don't mind the framerate in the window - it's just a side effect of the capturing)
I can't attach support.zip. the forum says it's too big (199k)
I cant watch the Video. But maybe the changelog solves you configuration problem.
Change: Main window: Best window size: For 4:3 monitors the height is adjusted (as before), for non 4:3 monitors the width is now adjusted to fit the window with the TV picture. You can disable the new adjustment via tweak -> see tweaker.exe.
http://www.DVBViewer.tv/comserver/lars/changelog.html
thanks for your reply.
it really helped, I didn't know about this tweaker.exe indeed.
I found, however, a vague reference about the parameter in the forum, and I have set it in the setup.xml manually before receiving your answer. :)
it was kind of a linux-feeling, to edit the xml file manually. :)
so now at last I can use the 5.0. :)
my EPG still buggy tough...
