Advanced VLC Option
Hi to all!!!
I would to manage with advanced option the OLD Method Streaming of DVBViewer Recordin Service,
I did't find also the debug log of the vlc trascoder/sreamer into webif.
Can we help me??
Thanks
what do you mean with advanced option?
some optimization like sout-keep command, and view the debug of vlc
ex. if i switch the channel and have blackscreen, WMP cut the connection and repeat in loop some minute of the streaming,
With sout-keep this not do :)
Edited by hidra
i have no clue where this should be applied, sorry. Maybe you can figure it out, just take a look at the webstreaming.ini. Remember to stop/start the RS on changes...
