farbus Posted March 5, 2013 Posted March 5, 2013 im not able to edit time zone settings I think the button to increase/decrease is missing Quote
deco Posted April 5, 2013 Posted April 5, 2013 confirmed and fixed. where is the fixed one?, because it's kinda annoying that the epg is out of sync because of this -Deco Quote
Griga Posted April 5, 2013 Posted April 5, 2013 I think you can change it by editing the file setup.xml (see configuration folder, DVBViewer must be closed). Im my setup.xml I find the following entries in the General section: <section name="General">.... <entry name="AutoTimezone">1</entry> <entry name="Timezone">120</entry>... The first one should be 0 in your case. The second one looks like "Difference to GMT" in minutes. Quote
deco Posted April 5, 2013 Posted April 5, 2013 thanks that's a temporary workaround, the 2 entries wasn't in my setup.xml, but adding them fixed it, well the the button to increase/decrease is still missing, but the epg is correct now. still wondering where the fixed version of DVBViewer is to be downloaded -Deco Quote
