EPG tags
Is there any documentation or way of getting a list and format of all the tags that I can use when importing EPG via the API?
I implemented an import feature for DVBViewer and the Recording Service in EPG Collector a couple of years ago but it's never been updated and is very simple compared to other imports I have done since.
I worked from that originally.
It doesn't document the possible tags, just suggests using the get EPG function and using the same tags that returns. The ones I see with my data are the same as a couple of years ago so maybe no progress.
Any devs listening for a change?
dont know what happened between fixpack 4 and 5 and recording service 1.25
but the collector is not working with this mix
only working collection and import is 4.1 fixpack 3 and recording service 1.24
