AC3Filter isn't enabled
avoidz
Hi, since updating to 5.0.0.0 the AC3Filter audio option doesn't seem to work. I have it selected as my AC3 Audio Decoder, but the icon no longer shows up in the Windows taskbar like it did before and so I can't configure any of its settings.
TV Audio source is either stereo or AC3.
I have sound when I watch shows, but was just curious why I can't use it now.
Thanks!
Edited by avoidz
Hi avoidz,
If the AC3 Filter is still available in the directx audio options then AC3 Filter.ax must still be registered. Try right clicking the video window, View/Filters/AC3
Filter. You should be able to get to the settings that way. Maybe when you installed DVBV 5.00 the filter reset to it's defaults and is not set to show the tray icon.
Hey, you're right. It is enabled. I just assumed when the tray icon wasn't there it was not working.
Well if I can't get the icon back at least I can still find the settings.
Thanks, mate :)
