VBS Refresh Recording Database
-lahna
Please help me.
I have made a VBS script that moves old record files to NAS server.
Now I need a help how to make a script to refresh recording database.
I posted a script (sourcecode included) that can run prozesstasks (ie. refresh recording database) here:
http://www.DVBViewer.tv/forum/topic/51926-processtasksex/
You can use run it from your vbs skript or translate the functions directly to vbs:
Func _Sendrequest($stask)
;bsp: http://192.168.1.100/tasks.html?task=CI_Reset&aktion=tasks
; http://192.168.1.100/tasks.html?task=CleanupRefreshDB&aktion=tasks
Local $user = IniRead($konfig_ini, "RecordingService", "User", "admin")
Local $pass = IniRead($konfig_ini, "RecordingService", "Password", "")
Local $IP = IniRead($konfig_ini, "RecordingService", "IP", "127.0.0.1")
Local $port = IniRead($konfig_ini, "RecordingService", "Port", 80)
Local $srequest = '/tasks.html?task=' & $stask & "&aktion=tasks"
Local $sHeader, $authorization = _Base64Encode($user & ':' & $pass)
Local $hOpen = _WinHttpOpen("Mozilla/5.0 (Windows; U; Windows NT 6.1; de; rv:1.9.2.6) Gecko/20100625 Firefox/3.6.6 GTB7.1")
Local $hConnect = _WinHttpConnect($hOpen, $IP, $port)
If @error Then
_FileWriteLog($log, "_Sendrequest - Fehler beim Verbinden mit dem Webserver INI überprüfen!", 1)
_WinHttpCloseHandle($hConnect)
_WinHttpCloseHandle($hOpen)
Return
EndIf
Local $hRequest = _WinHttpOpenRequest($hConnect, 'GET', $srequest)
_WinHttpSendRequest($hRequest, 'Authorization: Basic ' & $authorization)
_WinHttpReceiveResponse($hRequest)
If _WinHttpQueryDataAvailable($hRequest) Then $sHeader = _WinHttpQueryHeaders($hRequest)
Local $data = ''
Do
$data &= _WinHttpReadData($hRequest)
Until @error
If $exendetlog Then _FileWriteLog($log, 'process task=' & $stask, 1)
If $exendetlog Then _FileWriteLog($log, 'prozcss task return message: ' & $data, 1)
_WinHttpCloseHandle($hRequest)
EndFunc ;==>_Sendrequest
Func _Base64Encode($sData)
; keine Ahnung von wem die Funktion is (nicht von mir)
Local $oXml = ObjCreate("Msxml2.DOMDocument")
If Not IsObj($oXml) Then
SetError(1, 1, 0)
EndIf
Local $oElement = $oXml.createElement("b64")
If Not IsObj($oElement) Then
SetError(2, 2, 0)
EndIf
$oElement.dataType = "bin.base64"
$oElement.nodeTypedValue = Binary($sData)
Local $sReturn = $oElement.Text
If StringLen($sReturn) = 0 Then
SetError(3, 3, 0)
EndIf
Return $sReturn
EndFunc ;==>_Base64Encode
Edited by nuts
Thanks but I don't use the RecordingService. I only have a DVBViewer Pro.
I found an answer. Here for other newbies.
VBscript
option explicit
Dim DVB
Set DVB = getobject(, "DVBViewerServer.DVBViewer")
DVB.OSD.execproc("cleanRecordDB")
DVB.OSD.execproc("compressRecordDB")
DVB.OSD.execproc("refreshRecordDB")
Set DVB = nothing
VBscript
option explicit
Dim DVB
Set DVB = nothing
Or you use the ActionCommands -> http://de.DVBViewer.tv/wiki/Actions.ini
Dim DVB
DVBViewer.SendCommand(8261) 'cleanRecordDB
DVBViewer.SendCommand(8262) 'compressRecordDB
DVBViewer.SendCommand(8263) 'refreshRecordDB
Set DVB = nothing
Edited by Tüftler
