Go to suspend state after ending postrecording task?
jirim100
Hello,
when is enabled postrecording task (for example commercial removing) for timer - goes computer to suspend state AFTER ending this task (for timer is enabled suspend state)?
From the wiki http://en.DVBViewer.tv/wiki/Timer_concept_of_the_DVBViewer_Recording_Service
After recording task
These are normal Process timers, which will be generated on the fly by the recording timer. But only if the recording timer was not cancelled (means prematurely ended or deleted).
The newly created Process timer can not be saved, it expires if it gets cancelled or finishes. It inherits the Shut-down action of the recording timer. This way the Standby or Hibernate action of the original timer is processed after the Process timer finishes.
It means if you are using commercial removing as after recording task, RS will NOT wait for the script to finish and then go to suspend state. If using post record actions, computer will more probably go to standby during/in the middle of the commercial removing. If you want computer to go to suspend state after commercial removing finished you have to make it happen in the script. That implies all post recording actions (shutdown, standby and hibernate) for all recording timers has to be set to "nothing".
Check out the Scripting Lounge / COM (de/en) which covers how to do it.
Very thanks for answer, but then have to be in the script logic whether yes or not go to suspend state - checking whether is running some timer or will be started per, for example, 5 minutes.
Thanks.
I did some tests and Recording service correctly go to suspend state AFTER ending postrecording task. This is not true ! Probably you create in script another process and don't wait on ending it.
