crab2k Posted March 29, 2013 Posted March 29, 2013 Used for years older version of DVBViewer pro & RS, no problem. After a o.s. reinstall (xp sp3), I had to dowload the latest version of Dvb.5.0 and RS. Now, when I set up a new timer, strange things happens: -when selected from EPG it goes ok -when I try to change the start/ending time, the time go to 00:00 00:00 and there is no way to change it -sometimes, trying to change time, the timer vanish -the date of the timer change to the next week (from 29/3 to, for example, 5/4) -goes red and black without any reason Tried to unselect selectively the various servers and EPG but no result. I'd like to have a complete control of my timers, without automatic suggest (i.e. the current time when I click the time field, or the day) as the older version, is it possible? I've read all the wiki pages and the manual, but no ideas to solve this problem. Please, help me. Thanks, bye!
majstang Posted March 29, 2013 Posted March 29, 2013 when I try to change the start/ending time, the time go to 00:00 00:00 and there is no way to change it Seen reports about this kind of problem and the common thing seems to be you're using Windows XP. http://www.DVBViewer.tv/forum/topic/46411-autosearch/?p=342029 No solution in sight though, besides sticking with the old working DVBV/RS versions if continuing using XP.
crab2k Posted March 29, 2013 Author Posted March 29, 2013 (edited) Pffffff...... I've lost the old setup files, and you do not permit to download those... Can you create a download section of the last stable version for who has XP o.s.? Lot of persons wan't abandon it! Bye. Edited March 29, 2013 by crab2k
