channel xml or similar for sky uk......
c19ufc
Hi guys and gals,
If possible im looking for a Sky UK channel list that is pre sorted to hopfully save myself a lot of time, it would be great if some1 had 1 (not to bothered about the order as long as its logical) with grouped items, ie terrestrial togeather, kids togeather, sports together ect.
Hope my lazyness isnt asking to much, Im happy to either have it a file i can import into DVBViewer or xbmc.
Thanks in advance.
Tim.
I've got one of all the Freesat / fta channels
is it possible to add sky channels to that ?
No, I don't pick up the encrypted sky channels
  • 3 weeks later...
Here you go:
http://www.mediafire.com/view/?wgix044j14qesdh
include encrypted channels (not all but many) sky one, espn etc..)
You will have to change the frequencies for the channels on the high band (the ones using 22Khz tone) because i'm using a special LOF of 10750 instead of 10600 which is the standard.
Go to king of sat for that
Edited by themaster1
