Svg format logo support
DunnoX
Yes one more "idea" from me xD.
I don't know myself if it's really necessary but with resolutions going up 1080p,4k,8k,etc I think it would be nice to have a way to "stretch" logos without them losing quality.On 1080p i can already see pixelization on logos using png unless I use them with a higher resolution which basically occupies same size of the svg file (only tested on 4 logos).
Svg is very well documented easy to use and scalable to "infinity" and supported by all main browsers (even IE).
Have a nice day.
Where do you get the svg logos from?
Well the most popular channels have their logo on eps/svg/psd format for commom use for example http://www.rtp.pt/wportal/grupo/imprensa/rtpmemoria.php (from my country).
You can also look at http://www.brandsoftheworld.com example: http://www.brandsoftheworld.com/logo/bloomberg-tv?original=1
or http://logos.wikia.com/wiki/Logopedia
But you need to make sure they're really vector before exporting to svg (using ghostscript or illustrator etc)
