"Always on Top" not always on top loss of focus.
DunnoX
Hi, I think this is W$ related problem and not DVBViewer happens on almost every software that supports this feature (for example VLC has same behaviour).
Tested on W$ 8 Pro and on W$ 7 Pro.
"On top" and "input focus" are a different matter. For obvious reasons Windows usually doesn't allow applications to hold the focus all the time. Other applications would become unusable.
However, if this is a problem for you, you may want to try the KeepFocus Plugin that I've attached here. Store it in DVBViewer\ Plugins. After (re-)launching DVBViewer you will see a new item in the Plugins Menu enabling to switch "Keep Focus" on or off. The plugin checks every second if DVBViewer still has the focus and restores it if not.
Thank you for the plugin just what i needed didn't knew it was available you just made my day.
  • 4 weeks later...
for me too.
I'm using now DVBViewer 5.1.0.0
the problem is although i selected "View-->Always on Top" but some times where i open DVBViewer this feaure dosn't work.
as i found Griga suggested "KeepFocus Plugin"
Ok.
I'll try.
