How can I lock the PLS/MIS signal in TransEdit or Dvbviewer?
Hello!
How can I lock the PLS/MIS signal in TransEdit or DVBViewer?
You can't. It has to be set by an appropriate tool (crazyscan, TBSx925-TSRecorder) before tuning or analyzing. Remember to close the other tool before using transedit ;)
  • 1 year later...
Right now there are plenty of FTA Multistream stations on several satellites. When will DVBViewer Pro / TransEdit be able to scan them ?
I would like to use it instead of DVB Dream which looks to be the best in this field. Even SmartDVB partly suports MIS so why not DVBViewer Pro ?
Plenty? Name more than 5 MIS-transponders that you can receive ;) DVBViewer/Transedit are based on BDA. Proprietary hardware control doesn't fit in this scheme..
