Nikolaech Posted April 24, 2013 Posted April 24, 2013 (edited) Problem, fix. please if1: Open the folder C: \ WINDOWS \ system32 \ and locate the file "c_1251.nls" and "c_1252.nls" set full access to these files.2: Rename the file "c_1252.nls" to "c_1252.bak."3: Create a copy of the file here "c_1251.nls."4: Right-click on the file and select Copy.5: Right-click a blank area of the folder C: \ WINDOWS \ system32 \ and select Paste.6: Rename "c_1251 - duplicate.nls" in "c_1252.nls." As a result, the file "c_1252.nls", should be renamed copy "c_1251.nls"7: Restart the computer.Windows 8 pro x64. russian. DVBViewer 5.0 thank you.I use Google translator Edited April 24, 2013 by Nikolaech Quote
Antonio Posted April 25, 2013 Posted April 25, 2013 There will be problems with other programs for non-unicable applications (1251 RUSSIAN_CHARSET) Simplest in the Russian.lng file find and replace the next lines: pnlLook.Caption=&Поиск 41=%d канал(ов) %s 4=фильтрованный to replace on: pnlLook.Caption=Search 41=%d channel(s) %s 4=filtered Quote
Nikolaech Posted April 25, 2013 Author Posted April 25, 2013 Thank you Antonio! Restored file "s_1252.nls" changed on the recommendation of the file russian.lng in pointing out places appeared English font. It is advisable to fix the problem. Благодарю за помошь Антонио. В указаных местах появились английские аналоги русских слов. Это лучше конечно чем непонятный шрифт, тем не менее проблему желательно исправить. Удачи вам Quote
Antonio Posted April 25, 2013 Posted April 25, 2013 I asked to fix it one more year ago.. Maybe they have some any difficulties with this. http://www.DVBViewer.tv/forum/topic/21593-russian-language/page-2#entry356702 Quote
Nikolaech Posted April 25, 2013 Author Posted April 25, 2013 Thanks for help in locating the program. Quote
