Is DVBSky S950CI DVB-S/S2 natively compatible with Viaccess CAM?
trifon33
Hello,
I have just installed one DVBSky S950CI on new PC under Windows 8 64
Everything works flowless excepted some compatibility issue when using Viaccess CAM.
The CAM vendor is Smit...basic version i.e. no secure...
The unencryption process works ramdomly..difficult thus to use it...
I have found in the downloadable plugin one dll for the remote only...
DVBViewer 5
This question was not appropriate to the issue...
Please forget it....
