aldus1 Posted May 13, 2013 Posted May 13, 2013 I use two instances of DVBViewer in the same pc in two separate directory and name theexecutable as DVBViewer.exe and dvbviewer1.exe all work fine but when i use the scriptfor example:set DVBViewer = getobject(,"DVBViewerServer.DVBViewer")DVBViewer.sendcommand "16383"only the first instance receive the command, how can i tell to the script to use the secondinstance ? Quote
dbraner Posted May 13, 2013 Posted May 13, 2013 I think this is not possible using COM because the COM server could only be registered once (by the first instance started). But you can try to execute DVBViewer.exe and dvbviewer1.exe with the command line switch -x followed by an action id. Quote
Lars_MQ Posted May 13, 2013 Posted May 13, 2013 There is only ONE COM instance. It's a limitation of the Windows COM subsystem. Quote
erwin Posted May 14, 2013 Posted May 14, 2013 (edited) I use two instances of DVBViewer in the same pc in two separate directory and name the executable as DVBViewer.exe and dvbviewer1.exe all work fine but when i use the script for example: set DVBViewer = getobject(,"DVBViewerServer.DVBViewer") DVBViewer.sendcommand "16383" only the first instance receive the command, how can i tell to the script to use the second instance ? Syntax: WScript.GetObject (strPathName [,strProgID] [,strSubPrefix]) strPathName Receives the location of the file that will be loaded into the associated application. strProgID If the specified file can be handled by more than one application, this parameter accepts the ProgID of the particular application that you wish to use to load the file. strSubPrefix If non-empty, the CreateObject method will bind the events of the newly loaded object to event handlers beginning with the string passed to this parameter. Just an idea: Make an association for filtetype "*.dvbv1" with DVBViewer1. Create a dummy file "dummy.dvb1". set DVBViewer = getobject("dummy.dvbv1") Edited May 14, 2013 by erwin Quote
