Cablestar 2 frequentie problems.
Some 1 know if its possible to add offset for Cablestar 2?
Is only with DVBViewer that the frequentie is not working correct whene I use the original cable provider frequenties, all frequensties are offset bij -0.10Mhz or 0.01Mhz, is there a option that can fix this? of must I make a whole new list with offset frequenties?
