Audio problem
alexmusic
A small but quite annoying audio problem, don't know the cause. I explain:
Everytime DVBViewer is not running and I want to listen to some audio files with any player (Winamp, Windows Media Player, etc.), audio is full of breaks, it runs smoothly with some very frequent breaks.
If DVBViewer is running, the problem disappear. No matter what the codec is.
My system: Windows XP SP1, Intel Pentium 4 CPU 2.53 GHz, 512 MB RAM, with a SkyStar 2, NVidia Graphic card, DVBViewer Pro.
There is no DVBViewer.log in the folder.
MPEG2 Video Decoders:
DScaler Mpeg2 Video Decoder: 00800000
InterVideo Video Decoder: 00700000
MPEG-2 Video Decoder (libmpeg2): 00600000
MainConcept MPEG Video Decoder: 00600000
CyberLink Video/SP Decoder: 00600000
Nero Mpeg Video Decoder: 005FFFFF
SkyDVB Video Decoder: 00500000
MPEG Audio Decoders:
MPEG Audio Decoder: 03680001
DScaler Audio Decoder: 00800000
InterVideo Audio Decoder: 00700000
MainConcept MPEG Audio Decoder: 00600000
Setup.ini
Thanks!
Driver 4.2.11, now I try new driver, hoping the problem will be solved!
Installed new driver and the problem has been solved!
Thank you very much!
