MultiStream transponders
GinoFamussa
Hi Everybody,
Could it be possible to add a multistream option in the tuner , when a channel search is made?
I got this problem when I try to tune a transponder like this:
AtlanticBird 1 @ 12.5W
12718 H 36512 5/6 Dvb-S2 (Mutlistream 33;34;35;36)
and few other around the satellites.
no, not possible with BDA. It needs direct hardware control.
My PC card is TBS 6925.
This is a screenshot of another DVB player that I don't want to use.
and the transpobder searched is HB 13° tp 12 fr 11432v
Edited by GinoFamussa
I doubt that the dvbv devs will add the necessary direct hardware control in the near future. But what's the problem, if you have DVBViewer and progdvb? :D
I hate ProgDVB and besides, when both are installed, no one works well to me, particularly in managing the Diseq 1.0 switch.
It's years ago since I last tested progdvb. I would very much appreciate features like MIS and PLS in DVBViewer but I'm afraid that this won't happen. When I want to check e.g. Mediaset I use crazyscan to set the corresponding parameters before tuning with transedit ;)
