hahaha Posted June 16, 2013 Posted June 16, 2013 changes cannot be saved while the application. Thank you。 Quote
Tjod Posted June 16, 2013 Posted June 16, 2013 You must stop the Recording Service, before you can change its configuration. Quote
hahaha Posted June 16, 2013 Author Posted June 16, 2013 You must stop the Recording Service, before you can change its configuration. Thank you very much Quote
Tjod Posted June 16, 2013 Posted June 16, 2013 You image hoster blocks all non chinese IP addresses. So the pictures are not visible. Quote
hahaha Posted June 16, 2013 Author Posted June 16, 2013 (edited) You image hoster blocks all non chinese IP addresses. So the pictures are not visible. Edited June 16, 2013 by hahaha Quote
hahaha Posted June 16, 2013 Author Posted June 16, 2013 Could have been garbled, and now even display are not showing up. Quote
Tjod Posted June 16, 2013 Posted June 16, 2013 Stop the Recording Service and delete the epg.dat in configuration folder\config an run in the web interfacer > Tasks > Start EPG Scan Quote
hahaha Posted June 16, 2013 Author Posted June 16, 2013 (edited) Stop the Recording Service and delete the epg.dat in configuration folder\config an run in the web interfacer > Tasks > Start EPG Scan Still the same Edited June 16, 2013 by hahaha Quote
