xfox26 Posted June 26, 2013 Posted June 26, 2013 Hello, I have just purchased DVBViewer. Every time I choose a channel to display, the program closes without any message. I also downloaded the version DVBViewer GE from members area, and this works perfectly. I've tried completely uninstalling and reinstalling, but the problem persists. I've already double (and triple) checked my key data in KeyTool, and it shows exact like the info in my email. Someone can tell me why the major version of DVBViewer always closes when I select a channel? Sorry for the bad english, thanks! Quote
Gioxy Posted June 26, 2013 Posted June 26, 2013 (edited) Quite surely a Video codec issue: please refer to Wiki's Options DirectX page then please report here you findings/doubts/questions... Edited June 26, 2013 by Gioxy Quote
xfox26 Posted June 26, 2013 Author Posted June 26, 2013 Okay, I think i've fixed it.First, was EVR Renderer option that caused the program to close, VMR9 and VMR7 worked ok.But i've got a huge CPU usage (70~90%), so I decided to remove and re-install all codecs, after that EVR Renderer don't crash the program anymore and CPU usage is at 5% aprox.Thanks for the help. Quote
