Losing ATSC card signal in DVBViewer 5.0
BigBoyDale
Hi, Normally DVBViewer works great for me both in DVB and ATSC. Normally I switch between my ATSC channels and DVB channels seamlessly. I scan in my ATSC channels via DVBViewer, not transedit, and everything works fine. Until lately.
Sometimes for no reason my ATSC signal at the bottom of the window (which is normally green and at 90 percent for locals goes to zero. It's like the card is not being seen at all.
My satellilte prof card is fine. The TV card is an hauppauge and normally works beautifully.
I can go into DVBViewer hardware and the card shows up before and after a rescan.
I open transedit and the stations will scan into it no problem, so the card and drivers are fine. It's just like they are not being seen by DVBViewer.
I tried reinstalling DVBViewer, not a clean install but did delete it in add remove programs with no luck, still zero percent signal on all ATSC signals.
If I reimage the drive, everything returns to normal until the next failure which occurs in a few weeks.
If I try to use DVBViewer in order to scan in stations after the failure, it finds nothing.
If I put in another drive with another OS and another copy of DVBViewer, it works fine.
This is windows XP 64.
It's almost like a DLL is getting corrupt or something
Any ideas?
Thanks
Spencer
Here is what I'm getting in the DVBViewer log. Hope this helps.
zung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:00.125 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:00.140 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:00.156 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:00.171 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:00.187 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:00.203 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.265 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.281 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.296 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.312 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.328 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.343 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.359 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.375 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.406 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.421 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.437 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.453 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.468 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.484 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.500 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.515 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.531 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.546 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.562 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.578 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:02.609 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.109 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.125 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.140 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.156 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.171 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.187 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.203 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.218 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.234 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.250 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:03.265 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.687 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.703 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.718 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.734 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.750 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.765 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.781 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.796 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.812 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.828 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.843 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.859 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.875 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.890 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.906 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.921 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.937 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.953 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.968 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:05.984 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.000 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.015 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.031 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.046 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.062 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.078 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.093 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.109 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.125 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.140 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.156 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.171 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.187 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.203 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.218 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.234 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.250 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.265 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.281 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.296 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.875 EAccessViolation raised by instance of class TApplication at 004AA8F4:Zugriffsverletzung bei Adresse 004AA8F4 in Modul 'DVBViewer.exe'. Lesen von Adresse 022796D0
28.01.13 18:30:06.890 EInvalidPointer raised by instance cbMain of class TToolBar at 00402C04:Ungültige Zeigeroperation
28.01.13 18:30:06.906 EInvalidPointer raised by instance cbMain of class TToolBar at 00402C04:Ungültige Zeigeroperation
28.01.13 18:30:06.921 EInvalidPointer raised by instance cbMain of class TToolBar at 00402C04:Ungültige Zeigeroperation
28.01.13 18:30:06.937 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.953 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.968 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:06.984 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.000 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.015 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.031 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.046 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.062 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.078 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.093 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.109 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.125 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.140 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.156 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.171 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.187 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.203 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.218 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.234 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:07.250 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:10.656 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.218 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.234 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.250 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.265 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.281 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.296 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.312 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.328 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.343 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.359 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.375 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.390 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.406 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.421 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:11.437 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:16.609 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:16.656 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:22.859 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:22.875 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:22.890 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:23.812 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:23.828 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:23.859 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:23.906 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:23.921 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.015 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.031 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.046 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.062 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.078 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.093 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.109 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.125 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.140 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.156 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
28.01.13 18:30:24.171 EAccessViolation raised by instance pnlVideo2 of class TPanel at 0040547C:Zugriffsverletzung bei Adresse 0040547C in Modul 'DVBViewer.exe'. Schreiben von Adresse 428B1053
Rather than waste time filling out superfluous form templates, here's what I found...
Reinstalled a clean version of DVBViewer 5.1 after uninstalling 5.0. Upon reboot got a registry hive error. Have had this happen before.
Opened DVBViewer and set up hardware configurations.
DVB card (Prof7301) worked fine and scaned in fine.
ATSC card(Hauppauge), no scan signal at all.
There is nothing wrong with the hauppauge card and Win7 works fine with it.
However,
I had another TV card, an ATI all in one wonder, installed in computer, but not being used.
Plugged antenna into that card and scanned with DVBViewer and it scans fine.
My thoughts.
I believe I have a hard drive going bad as I have had several hive errors with this drive recently. The only way to correct this is to do a registry restore with a boot disk of a recent restore point using registry restore software in order to get the hauppauge card working again. i DON'T THINK THIS IS A FIX, MERELY A WORKAROUND. Installing the new card must have set new values and hopefully the damaged area's in the hard drive are not being accessed. REPLACING/REIMAGING WITH A NEW HARD DRIVE IS THE BEST LONG TERM SOLUTION.
I believe DVBViewer is merely the symptom and not the underlying problem. I did try some other programs, thinking I might go to them for my TV viewing, however nothing comes close to DVBViewer, I can honestly say. Hope someone can use this info as I googled the exception error and it has come up on this forum with no solutions.
