Avermedia volar green HD
Coolmicro
Hello,
I'm french, sorry for bad english
I have a Avermedia volar green HD (USB), connected to a PC and an antenna group TNT.
With the soft AverTV 3D, everything is ok
With the soft Pouchin TV mod, everything is ok
With DVDviewer (paid pro version), I get no channel, nothing.
I used DVBViewer Pro-wizard, I did not have any particular problem. In the wizard, there were 2 cards found :
USV Digital TV
AF9015 BDA Filter
I tried checking them both, and then selecting one, but no results
In Pouchin TV mod, he had to choose AF9015 BDA Filter so that it works
I'd use DVBViewer to use XBMC frontend
Best regards
Hello,
Here is the file support.zip
My HTPC : Arctic cooling MC101 - AMD Trinity A10 - 4600M - AMD HD7660G - 8 Go RAM - Windows 8 64 bits
My tuner TNT : Avermedia volar green HD (USB)
What happens if you try to run a channel scan im DVBViewer Pro?
Nothing, there is no channel
Yet it is a very good collective antenna (TNT Numéricable France) => 100% for all channels with other software (Pouchin TV mod, Avermedia software)
Edited by Coolmicro
Set the "USB Digital TV (1)" to don't use.
http://en.DVBViewer.tv/wiki/Options_Hardware
Start the DVBViewer via start menu > program files > DVBViewer > Support > DVBViewer Pro (Debug Mode)
And try to run a channel scan. If it don't work enable "USB Digital TV (1)" and set "AF9015 BDA Filter (2)" to don't use.
With your advice, it works
Thank you
