Program stops displaying / recording channels by itself
floyd6
Every time I try to record some channel the program stops displaying it and also stops recording after a few minutes without any message whatsoever, although the record icon is still there.
This started happening after I enabled the program to run in Windows XP SP3 compatibility mode on Windows 7. Before that the program was crashing randomly. I did that because it worked fine on Windows XP.
I've tried selecting different decoders but that did not solve the problem.
I'm using version 4.5.0.0
Please help!
post-139345-0-06697400-1374080799_thumb.jpgpost-139345-0-75972600-1374080803_thumb.jpgpost-139345-0-00632900-1374081062_thumb.jpgpost-139345-0-57116300-1374081064_thumb.jpgpost-139345-0-35534600-1374081067_thumb.jpgpost-139345-0-07615800-1374081070_thumb.jpg
My suggestion is:
Reinstall Win 7. Don't install any decoders, Win 7 have what you need.
Install latest version of DVBViewer. Don't use XP compatibility mode, it is not needed
