highyield Posted July 19, 2013 Posted July 19, 2013 (edited) Open the Scan channels window. You have to select Cable or Terrestrial as reception type (is "Terrestric" a correct word?), select a transponder list and press Scan Frequency. No real channels are needed. Now, close the Scan window and open it again. There's a text box and a drop-down list (with two options, E and W) that shouldn't be there. They always appear when opening the Scan channels window, if the last selected transponder list is other than "None". This bug is not new. Edited July 19, 2013 by highyield Quote
