BDA drivers not detected with HD Homerun in 5.2
pssonline
My HD Homerun is detected and works correctly in DVBViewer 5.1, however updating to 5.2 appears to break this as no device is picked up in the scan at all.
Any help is appreciated.
I'm back to running 5.1 at the moment but can reinstall 5.2 and attach files if required.
Thanks,
John
Hi, can you provide us the latest support.zip (and could you start the application with parameter -debug)?
Hi, reinstalling 5.2 again from the same downloaded file over the existing 5.1 install this time saw the hardware show up in the device scan but not available for use.
Please find support.zip and the debug log attached.
Thanks,
John
debug.log
Thanks for your efforts.
We have found the reason for this issue, and it will (hopefully) be fixed in the next release. It was indirectly caused by this event. Unfortunately Lars had no opportunity anymore to finish the code enhancements that he had in mind.
My condolences for your loss.
