MCE Remote sleeping
rasmuzzen
Am I the only one who has problem has a problem with MCE remote, it is in some kind of sleeping mode when DVBViewer has been showing the same channel for hours. Pressing "back" and "ok" a lot of time makes the program react to the remote again. It is the old reciewer and remote from microsoft Im using made for the MCE called MCE 2005 in the program. Problem started about version 5.X of DVBViewer. The reciever shows with the red led that it is reciving remote signal.
Grettings from Roskilde - DK
  • 1 month later...
Hi
had similar issues...
try using eventghost and there is also an MCE remote plugin available...
you could also check your BIOS and windows settings for sleep/hibernate/power saving and try leaving them always awake
wake on USB input found within some BIOS might help as well...
