gabrago Posted November 6, 2004 Posted November 6, 2004 If I program a record from (23:45 to 00:55), DVBViewer automatically change it to (11:45 to 12:55). Why? attached.zip Quote
Griga Posted November 6, 2004 Posted November 6, 2004 Checked it - doesn't happen here with DVBViewer 2.3 Beta. Have a look at you date & time settings in Windows. Something special there, e.g. 12 hours format instead of 24 hours? Quote
gabrago Posted November 8, 2004 Author Posted November 8, 2004 I think there is a little bug in windows xp sp2 that I have previously installed. Now I have forced the symbol AM or PM to appear in the format of the hour, in control panel-->international options ( there is no possibilty to set the visualization of time in 24 hour format when I double click in the time icon in the system tray) and it seem that dvb task scheluder performs correctly. Quote
Hartwig Posted November 8, 2004 Posted November 8, 2004 You can change the clock to 24h format under start/settings/systemsettings and then (Sorry for my german) "Regions und Spracheinstellungen". Then "Anpassen". I hope you know what I mean (see the picture). Use "HH" fo 24 h Format and "hh" for 12 h Format Quote
gabrago Posted November 10, 2004 Author Posted November 10, 2004 Yes, you're right! Thank you very much. Quote
