Zzipper Posted August 12, 2013 Posted August 12, 2013 Hello, since I updated to 5.2.7 I can't sort channels by name nor by categorie. See the pic. Quote
hackbart Posted August 13, 2013 Posted August 13, 2013 Hi, yes confirmed and fixed. There is a Bug inside the VirtualTreeview we are using which caused this issue. I had replaced the newer version with an older one, in order to allow usage of screen readers. Quote
Zzipper Posted August 13, 2013 Author Posted August 13, 2013 Ok, but I don't have the old files to replace in the new versions folder. What should I do. Do you plan to release 5.2.8 to fix that? Quote
Griga Posted August 13, 2013 Posted August 13, 2013 The DVBViewer Pro 5.1 installer is still available in the members area, section "Older Versions". Quote
