jkinnunen Posted August 21, 2013 Posted August 21, 2013 Hi,I have problems using DVBViewer Pro 5.2.7 with the NVDA screen reader. Specifically, the tree view control is inaccessible which means that it is no longer possible to navigate in the channels, EPG, timer or the options window. The latest version of DVBViewer that worked well was 5.1. I'm running NVDA 2013.2 RC1, by the way. Thanks and regards, Jani Quote
hackbart Posted August 21, 2013 Posted August 21, 2013 Hi, well there still might be a problem with the virtualtreeview we are using. I downgraded to an older version, but probably not the one which was working fine with screen readers. Christian PS: I downgraded to yet an older version in the hope that this one will work fine with the next release. Quote
jkinnunen Posted July 30, 2014 Author Posted July 30, 2014 Hi Christian, This problem still exists in DVBViewer 5.3.1. Can you downgrade the virtual tree view control yet again or do something else to fix this? Thanks, Jani Quote
