Benzon Posted August 22, 2013 Posted August 22, 2013 Hi,Quite new in here, used time on reading documentation, but i got a problem, i can stream via Unicast with out any problems, when opening my EPG and trying to Send to PVR, nothing happens no error's and there is no timers created on the RS, tryed disabling firewalls, but with out any luck, any one got a idea what i have to do?
majstang Posted August 22, 2013 Posted August 22, 2013 Did you follow these instructions? http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer
Benzon Posted August 22, 2013 Author Posted August 22, 2013 Changes at the hardware configuration This page shows the changes at the hardware settings which will be made. If the RS is installed on this PC let the wizard disable local DVB devices. Now DVBViewer is ready for action. Sometimes a DVBViewer restart is necessary. Ain't sure about this step, it's some what unclear, but the RS server is setup, and if i use the EPG, in DVBViewer on the server it self, there is no problems, just when trying to push it from here, to he server.
Benzon Posted August 22, 2013 Author Posted August 22, 2013 I am just a retard - did not see the setup recording service wizard for a long long time, but now it works thanks
