EPG Issue - Maybe a bug.
Benzon
Found a minor issue, wheni open up the epg, on a DVBViewer client, running true RS, you can only plan recordings from the EPG tab in the epg windows, you if you ask it to send to PVR, from Whats on now, or timeline, nothing happens.
Noticed in RS, that the webinterface, is doing somewhat the same, might be a bug, migt be a glitch, or is it intended to be this way? because it dont make that mutch sence :)
