Guest hackbart Posted December 20, 2002 Posted December 20, 2002 I know i've posted it already, but it can be found under: www.DVBViewer.com/download/pluginsrc.zip The first one is the .mdb reader plugin, which needs an free odbc vcl to be compileable (i forget the name of the author) The second one is some sort of childlock. It is able to put own items into the menubar, so you could configure your homemade plugin in the DVBViewer. It receives the DVBViewer handle and of course a message, if a channel will be switched. For remote control you should take a look into the remote example. The Plugin-Architecture is knowingly damn simplistic, because i wanted to allow everybody to get their own working plugin without having too much headache. Christian Quote
Guest DAvenger Posted September 3, 2003 Posted September 3, 2003 A couple of sample modules (no SDK yet) for RadLight 4 (thus for DVBViewer 2) can be found here : http://www.radlight.net/forum/index.php?showtopic=241 Quote
