Ganryu Posted September 19, 2013 Posted September 19, 2013 Hello, I recently purchased and installed DVBViewer and I find it very good. I have one question though : - When I look at EPG it is displayed with very small fonts. It could be ok on a computer screen but from far away on an HD TV it is quite unreadable. Is there a way to increase the font size used by DVBViewer especially with EPG? Quote
Webturtle Posted September 19, 2013 Posted September 19, 2013 (edited) Hello, on a computer you can change the size of the EPG-text, if you make a right click on the text window (context menu). If you are using the OSD, you could look in the "options - OSD" if there is a possibility to change the size. If you are using a the computer and not a remote control you could try a right click too. Many greetings Webturtle Edited September 19, 2013 by Webturtle Quote
Ganryu Posted September 30, 2013 Author Posted September 30, 2013 Thank you very much,I will try that. I havent found how to access the OSD. I use a mouse and right cliking brings a lot of possibilities but not the OSD. Quote
Gioxy Posted September 30, 2013 Posted September 30, 2013 Thank you very much,I will try that. I havent found how to access the OSD. I use a mouse and right cliking brings a lot of possibilities but not the OSD. Usually (you can program it differently) OSD was opened by "central" mouse button, not "right" mouse button; or you can also use "Esc" keyboard key... Quote
lauris90 Posted October 1, 2013 Posted October 1, 2013 (edited) I have a problem with EPG (NO EPG, only for 3 channel) using DVBveiwer and RS, how can i fix that? Im using DVB-S Edited October 1, 2013 by lauris90 Quote
Gioxy Posted October 2, 2013 Posted October 2, 2013 Welcome to the EPG struggle! ...out of the joke, not all channels/providers are sending EPG, but there are some alternatives to get it, mainly depending on you have DVB-T or DVB-S or cable device: pls begin taking a look at Option Service - EPG wiki page and at Delphi's Xepg... Quote
