airstar2 ?
peo
HI
I have this card and n this moment using with the viewerTE
I will know if the full version of DVBViewer work with the airstar2 ( the viewerTE i not too stable)
more inprtant for me is if the soft can disply and recorded the Finnisch subtitles
Im living in Finland and here all program have subtitles so is very inportant function
ciao
The new beta can show norway subtittle and normal subtittle.
But what is so special for finish subtittles?
@Christian: Do you need a betatester in Finland? Here is your chance ...
ciao
in finland on sat channal and terrestrial all channal have the origial soundtrack (no dubbed program) they put subtitles everyware :P
thats means the subtitle must be diplayed and recorded in auto mode in all channal
ciao
Guest hackbart
Well i already have one user and he found out a problem in the SDT parser which caused weird channel names. Right now i do some finetuning - since it seems that the finish subs are a BIT mot special. But the new official version will have a solution to save and playback dvb subtitles (and more than just one)
Christian
ciao
yes the dvb viewerTE have that problem
so 4 the next upgrade is possible tu see subtitle and record subtitle???
in fin
wen is coming out the new upgrade??
anyway if u need a beta tester.....................
have 1airstar2 and 1skystar2 :P
